Stopping and starting the Oracle Life Sciences InForm Publisher application
Click the Start or Stop button in the upper-right corner of the Oracle InForm Publisher Configuration dialog box.
You can enable or disable event publishing by selecting the Event Publishing Enabled checkbox. If you disable event publishing and have subscribers defined, events will not be transmitted to subscribers.
