pf:CustomEvent element
This extension denotes the custom event for which the ODM XML is published.
XPath
ODM/ClinicalData/pf:CustomEvent
Attributes
| Attribute | Description |
| Name | This attribute is the custom event destination name that is defined in Oracle Life Sciences Central Designer. This name can be meaningful to the receiving application. |
| Destination | Name of the destination that the Oracle Life Sciences InForm Publisher application uses to locate the endpoint to which it sends the custom event XML. |
| StudyVersion | Study version to which this custom event is assigned. |
| EventID | Internal numeric identifier of the custom event. |
| EventRef | Revision number of the custom event. |
Parent topic: ODM structure for custom event output
