Radio and Checkbox groups
The item in the InForm study:
This item is composed of a radio group containing three options:
- A checkbox group with caption Yes that contains three options:
- A simple control Parent.
- A simple control Sibling.
- A text box with caption Other.
- A simple control: No.
- A simple control: Unknown.
Criteria to determine whether an item is complete:
- If nothing is selected, then the item is incomplete.
- If No is selected, then the item is complete, because No does not have any children of its own (it is a simple control).
- If Yes is selected, but no checkbox options are selected, the item is not complete because at least one checkbox must be selected.
- If Yes is selected and Parent or Sibling is selected, then the item is complete, because Parent and Sibling don’t have any children of their own.
- If Yes is selected and Other is selected, but the text box is not filled in, then the item is incomplete.
