Previous Topic
Next Topic
Book Contents
Elements and extensions change history
The following table contains a history changes to elements and extensions and the InForm Adapter release when they were introduced.
Extensions change history
Release
Change details
InForm compatibility notes
1.3.9
  • StudyEventDef element—pf:VisitStartHours attribute added.
Compatible with all studies designed in Central Designer.
1.3.7.3
  • The way in which ReviewState and ReviewStage are represented under the SubjectData element was changed.
1.3.7
  • User element—pf:InFormUserType element added.
1.3.6.1
  • ItemGroupDef element—The following attributes were added:
    • pf:RowCount
    • pf:IsFixedStatus
    • pf:UsePredefinedValue
  • ClinicalData element—pf:CriticalItems attribute added.
  • InFormItemDef element—pf:SVCritical attribute added.
  • ItemGroupDef element—pf:SVCritical attribute added.
No values for InForm releases prior to 6.0.
1.3.6
  • User element—pf:Active and pf:Terminated attributes added.
1.3 SP5
  • FormStatus element—pf:SVSelected attribute added.
  • New elements added:
    • pf:ReviewState
    • pf:ReviewStage
    • pf:SubjectPool
    • pf:SubjectPoolChange
No values for InForm releases prior to 5.5.
Send Feedback
