Response—GetTransactions
Returns an XmlElement that contains the subject transaction data (such as form submissions) for subjects who match the specified patient ID. The subject data is located under the /ODM/ClinicalData XPath in the returned XML.
GetTransactions response |
Node/Attribute name |
Description |
Description |
The description of the study. |
FileType |
For InForm data, FileType is always Transactional, indicating that an InForm transaction is returned. |
FileOID |
A unique identifier for the file. Consists of the study.name followed by a GUID. For example: pfst/{345C8404-9656-425B-BA03-EE92D7E1FE91}
PriorFileOID |
An identifier for the transaction that was retrieved by the previous API call. |
CreationDateTime |
The date and time when the API call was made. |
ODMVersion |
The version of the ODM schema of the returned data. |
Originator |
The ID of the user who made the API call. |
TransactionsProcessed |
Indicates the number of transactions that were considered by the method. Note: This number is not the same as the number of clinical data transactions that are returned. Some transactions do not contain clinical data. |
Bookmark |
The bookmark that must be passed into the next call to GetTransactions. Indicates the point in the transaction log after which the processing should begin. For more information, see Usage—GetTransactions. |
MetaDataVersionOID |
Identifier for the study version of the form in the InForm system. If the form does not contain a study version, MetaDataVersion is returned with the value "Undefined." This represents the column EditionDescription found in the pf_volumeEdition table. If there is no volumeEdition associated with a particular site the value is "Undefined." |
For more information, see:
