Candidate element
The Candidate element is returned when a screening or enrollment action is performed in the InForm application.
XPath
ODM/ClinicalData/SubjectData/pf:Candidate| Parent element | Child elements |
| SubjectData |
DOB. ScreeningDate. |
Attributes
| Attributes/children: Candidate | Description |
| DOB |
Date of birth of the candidate. type=TypeDATE. |
| ScreeningDate | type=TypeDATE. |
| PatientGuid |
The GUID of the candidate. type=TypeGUID. Required. |
| Revision |
The revision number of the subject type=TypeREVISION. Required. |
| SiteGUIDREF |
The GUID of the site. type=TypeGUID. Required. |
| Initials |
The initials of the subject type=TypeINITIALS. Required. |
| State |
The state of the subject. type=TypePatientSTATE. Optional. |
| ScreeningNumber |
The candidate's screening number. type=xs:String. Required. |
| EnrollmentNumber |
The subject's enrollment number. type=TypeENROLLMENTNUMBER. Required. |
| ScreeningFailure |
The reason for screening failure. type=xs:string. Required. |
| EnrollmentFailure |
The reason for enrollment failure. type=xs:string. Required. |
| EnrollmentOverride |
The reason that the enrollment failure was overridden. type=xs:string. Required. |
| PatientNumberRevision |
The revision number of the patient number. type=TypeREVISION. Optional. |
Parent topic: Oracle ODM extensions
