Error messages from the Discrepancy interface
| Error Code/MessageID | Operation | Error |
| TRANSACTION_PROCESSING_ERROR | N/A | An error occurred processing a transaction {0}. |
| DISCREPANCY_AGAINST_CALCULATED_ITEM | Issue | Cannot issue a discrepancy against a calculated item. |
| INFORM_FORM_REPEATING_NO_DATA | Issue | Cannot issue a discrepancy against a repeating form that has no data. |
| DISCREPANCY_AGAINST_ITEMSET_ROW | Issue | Cannot issue a discrepancy against an itemset row. Must issue against an item in the itemset. |
| DISCREPANCY_TRANGEN_NOTCREATED | N/A | Could not create an instance of the transaction generator. |
| DISCREPANCY_ELEMENT_NOTCREATED | N/A | Could not create element. |
| DISCREPANCY_DBUID_NOTFOUND | GetByCriteria, Issue | Could not find an item associated with the requested Dbuid: {0}. |
| DISCREPANCY_GUID_NOTFOUND | GetHistory, Update | Could not find an item associated with the requested Guid: {0}. |
| INFORM_FORM_NOTFOUND_DETAIL | N/A | Form not found: {0}. |
| MAPPEDITEM_ENTRY_BLANK | N/A | Found a mapped item entry for item {0} but it is blank. |
| DISCREPANCY_INVALID_USER | N/A | Invalid user specified. |
| PATIENT_GUID_NOTFOUND | N/A | Patient with GUID {0} not found. |
| INFORM_DISCREPANCY_STATECHANGE_NOTALLOWED | N/A | State change not allowed from {0} to {1}. |
| MAPPEDITEM_PATH_CHAPTER_NOTSPECIFIED | N/A | The chapter is not specified in the mapped item path: {0}. |
| INFORM_FORM_DELETED | N/A | The Form is deleted. InForm does not allow query management on a deleted form. |
| INFORM_FORM_LOCKED | N/A | The Form or Visit is locked. InForm does not allow query management on a locked form. |
| TRANSACTIONID_INVALIDFORMAT | N/A | The format of the requested TransactionId is invalid {0}. |
| MAPPEDITEM_PATH_ITEM_NOTSPECIFIED | N/A | The item is not specified in the mapped item path: {0}. |
| MAPPEDITEM_CHAPTER_MISMATCH | N/A | The mapped item's chapter '{0}' must match the requested item's chapter '{1}'. |
| MAPPEDITEM_ITEMSET_MISMATCH | N/A | The mapped item's itemset '{0}' must match the requested item's itemset '{1}'. |
| MAPPEDITEM_PAGE_MISMATCH | N/A | The mapped item's page '{0}' must match the requested item's page '{1}'. |
| MAPPEDITEM_FORMAT_INVALID | N/A | The mapped item's path is invalid: {0}. |
| MAPPEDITEM_SECTION_MISMATCH | N/A | The mapped item's section '{0}' must match the requested item's section '{1}' since the item resides in an itemset. |
| MAPPEDITEM_PATH_PAGE_NOTSPECIFIED | N/A | The page is not specified in the mapped item path: {0}. |
| DISCREPANCY_REQUEST_CRITERIA_INPUT_LIMIT_EXCEEDED | N/A | The request contained {0} values for {1}. The limit is {2}. |
| TRANSACTIONID_INVALID | N/A | The request must contain a valid TransactionId. |
| INFORM_ITEM_HIDDEN | N/A | The requested InForm item is hidden. |
| REQUEST_LIST_EMPTY | N/A | The requested list is empty. |
| TRANSACTIONID_DUPLICATE | N/A | The requested TransactionId {0} is a duplicate. |
| MAPPEDITEM_PATH_SECTION_NOTSPECIFIED | N/A | The section is not specified in the mapped item path: {0}. |
| DISCREPANCY_BOOKMARK_INVALID | N/A | The specified bookmark "{0}" is invalid for the current request. If a request includes a bookmark, it should be a bookmark that was returned in the response from the matching request. |
| DISCREPANCY_INVALID_REVISION | N/A | The specified discrepancy revision number {0} does not match the latest revision number {1}. |
| INFORM_FORM_INDEX_INVALID | N/A | The specified form index {0} is invalid. |
| INFORM_FORM_REVISION_STALE | N/A | The specified form revision {0} is not the most recent. |
| DISCREPANCY_INVALID_SITE | N/A | The specified site {0} is invalid for patient {1}. |
| DISCREPANCY_INVALID_STATE | N/A | The specified state is invalid: {0}. |
| INFORM_VISIT_INDEX_INVALID | N/A | The specified visit index {0} is invalid. |
| INFORM_TRIALCONN_NOTFOUND_TRIAL | N/A | Trial Connection for trial {0} was not found. |
| INFORM_TRIALCONN_NOTFOUND | N/A | Trial Connection not found. |
| INFORM_USER_NOTFOUND | N/A | Trial User not found. |
| DISCREPANCY_LSID_NOTCREATED | N/A | Unable to construct an LSID. |
| INFORM_ITEM_PARSE_ERROR | N/A | Unable to extract an InForm item from the requested XML. |
| INFORM_VISIT_NOTFOUND_DETAIL | N/A | Visit not found: {0}. |
Parent topic: Discrepancy interface
