Input parameters—DownloadAdminDataODM
DownloadAdminDataODM input parameters
Takes an XmlElement that follows the DownloadAdminDataODM element schema as an input parameter. The DownloadAdminDataODM element has the following children.
| Node/Attribute name | Description |
| trial |
The study from which to retrieve administrative data. Specify either the study name, or the study alias value that is used when registering the study through the Oracle InForm Adapter Admin interface. |
| userName | The user ID of the user who is requesting the data. |
| priorFileOID |
Optional reference to the previous file (if one exists) in a series. Type = String. |
| fileType |
The type of ODM file data that is to be returned. Type = Enumeration. Enumeration values = Transactional. |
| mappingVersion |
The version of the InForm-to-ODM mapping. Specify 2.0 for the most complete and accurate representation of the InForm data that is returned in ODM format. Type = Enumeration. Enumeration values = 1.0, 2.0. Default = 2.0. |
| includeExtensions |
Specifies whether to include Oracle Phase Forward ODM extensions in the data that is returned from the method. Type = Boolean. Default = True. |
complianceMode
Specifies how to handle transactions in the study that are deleted and then undeleted. Type = Enumeration. Enumeration values = Strict, Loose. Default = Strict. Strict or Loose has no affect on admin data or metadata. |
includeUsers includeLocations includeSignatures includeGroups includeLocales |
Parameters that specify a section in the admin data to be returned with the response. includeUsers is required if you want to specify userBookmark. Type=Boolean. Values=True or False. Default=True (the section is included). |
| userBookmark |
The Oracle InForm UserID. You must specify includeUsers if you want to specify a userBookmark.
Parent topic: DownloadAdminDataODM
