Input parameters—GetByDiscrepancyGuid
Takes a DetailByGuidRequest XML element as an input parameter.
DetailByGuidRequest takes one or more study names, each with an associated list of Discrepancy GUIDs.
DetailByGuidRequest
| Parameter | Description |
| authenticationTrialName | The study in which the discrepancies are issued or updated. If username/password authentication is enabled, the username and password that you specify in the SOAP header are authenticated against this study name. |
| StateChangesAfter |
If specified, only the records that have changes in state that occur after this date are include in the result set. Date format: YYYY-MM-DDTHH:MM:SS |
| DiscrepancyGuidList |
A list of GUIDS associated with the specified study name. Maximum number of GUIDs in a single request: 1000. |
| Bookmark |
A response includes a bookmark if there are more records that match the requested criteria. The caller passes in this bookmark on a subsequent call to return the remaining records. Absence of a bookmark indicates that the caller wants to receive the first set of records that match the criteria. Note: When using bookmarks, the subsequent requests must be identical to the first request. If you use different parameter values in subsequent calls, errors and unexpected results will occur. |
| ResultsetSize |
The number of records to be retrieved in a single call. Default: 1000. Maximum: 2000. |
Parent topic: GetByDiscrepancyGuid
