Input parameters—GetByTransactionId
Takes a DetailByTransactionIdRequest as an input parameter.
DetailByTransactionIdRequest has the following parameters.
| Parameter | Description |
| authenticationTrialName | The study in which the discrepancies are issued or updated. If username/password authentication is enabled, the username and password that you specify in the SOAP header are authenticated against this study name. |
| TransactionId | A GUID that is used to identify the particular transaction. |
Parent topic: GetByTransactionId
