Input parameters—Issue
Takes an issueRequest XML element as a child element.
IssueRequest takes a list of InForm items, referenced by GUID, DBUID, or an InForm item type that allows the specification of data that is found in an LSID.
A request can be made for a single study. A request that contains multiple items is treated as an atomic transaction.
Hidden items
A hidden item is an item that is globally hidden.
A request to issue a discrepancy on a hidden item generates an error.
Issue
| Parameter or child element | Description |
| authenticationTrialName | The study in which the discrepancies are issued or updated. If username/password authentication is enabled, the username and password that you specify in the SOAP header are authenticated against this study name. |
| transactionId |
A GUID created by the caller. TransactionID is not case sensitive. It must use one of the formats described in TransactionID GUID format. This parameter prevents a transaction from being submitted multiple times. If you specify a value that was previously submitted and resulted in a successful transaction, an error occurs. |
| transactionUserName |
The user name of the InForm user to associate with this transaction. The user must belong to a query group in an InForm trial. If using the InForm Adapter with InForm 6.0 or later studies that are configured to work with single sign-on, the OrgID value must be prepended to the trial username to match the tenant-qualified username that is used by the single sign-on application. |
| InFormItemIdentifier |
A unique identifier of an Oracle InForm item:
| InitialState |
The state in which the query is to be opened. Values: Candidate, Opened. |
| Reason | The reason for issuing the discrepancy. |
| ValidateOnly |
Values: True, False. If True, both of the following occur:
Parent topic: Issue
