Schema files provided with the ODM Export interface
Schema files for requests and response are located in the InForm Adapter installation directory.
<installation_directory>\ODM\bin\xsdValidate ODM requests and responses against the following schema files:
Request schemas:
- Top level file: ODMParameters.xsd
Sub level file: ODMParameters2.xsd
Response schemas:
- Top level file: ResponseODM.xsd
Sub level files:
- ODM.xsd
- ODM1-2-0.xsd
- PFExtensions.xsd
- PhaseForward_ODM.xsd
Most web service toolkits can be used to validate XML.
Validation assures that request XML has the correct parameters and is of the right type to be used by the Oracle ODM Export methods, and that responses have valid XML to be used as input in other programs.
Parent topic: ODM Export: XML schemas
