SOAP header
The SOAP header contains information about the service, the message, and the sender. It must include all of the fields shown.
The requirement for requests to contain the wsu:Timestamp, wsse:Username, and wsse:Password elements is defined in the WSDL by ws-policy. The URLs to include are:
wsa—http://www.w3.org/2005/08/addressing (username/password authentication)
wsu—http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd (username/password authentication)
wsse—http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd (signing in with X.509 cert (F5CERT))
If your web service toolkit does not support ws-policy, you must manually add these elements to the web service request.
Username authentication
| Field | Description | Standard |
| wsa:Action | SOAP action for the operation. Include this field as part of the summary for each SOAP operation. | WS-Addressing |
| wsa:MessageID | Unique ID for the message. | WS-Addressing |
| wsa:ReplyTo | Use the value that is shown in the example. | WS-Addressing |
| wsa:To |
Full URL of the service. Note: The full URL is different for each customer. |
WS-Addressing |
wsu:Timestamp
Time the message was created and when it expires. Oracle recommends a 5-minute time window. The software allows for five minutes of clock drift between servers. This value can be modified in the web.config file by setting the MaxClockSkew value. |
SOAP Message Security 1.0 |
| wsse:Username | User name of the user in the Oracle InForm study. | SOAP Message Security 1.0 |
| wsse:Password | Password of the user in the Oracle InForm study. | SOAP Message Security 1.0 |
F5CERT Certificate authentication
Request Headers:
| wsa:To |
WS-Addressing |
| wsse:Security | Provides the X.509 Certificate Token, time stamp, and the signature. | SOAP Message Security 1.1.1 |
wsse:Security/wsu.Timestamp
| wsse:Security/BinarySecurityToken | The X.509 certificate referenced within the signature. | SOAP Message Security 1.1.1 |
| wsse:Security/Signature | The signature of the soap body. | XML Signature Syntax and Processing (Second Edition) |
Response Header:
| wsse:Security | Provides the signature confirmation. | SOAP Message Security 1.1.1 |
| wsse:Security/wsse11:SignatureConfirmation | Contains the contents of the <ds:SignatureValue> element of the request signature as the value of the @Value attribute of the <wsse11:SignatureConfirmation> element. | SOAP Message Security 1.1.1 |
Parent topic: Programming model and operations
