Using a bookmark
To return all user admin data in multiple calls and responses:
  1. In the first call to DownloadAdminDataODM, obtain the Signature, Locations, and Users sections, but limit the number of users to return by specifying a user bookmark with a value of zero (0).
  2. In the second call, DownloadAdminDataODM again, this time using the bookmark that was returned by the first method call. This will return only the User section, starting with the first record after the userBookmark.
  3. Make additional calls with the same parameters. Check to determine whether all users have been returned by either checking for the status node, or determining whether the bookmark node in the response is the same as the userBookmark in the request.
