Locales in the Reporting and Analysis module
There are multiple locales that affect the languages that appear in the Reporting and Analysis environment:
Default product locale
- Set during the Oracle InForm installation.
- Controls the language of the prefixes for clinical metadata, such as Code~, Unit~, and Date~, which appear in the Cognos Reporting tree.
Reporting product locale
- Based on the default or user product locale settings in the Oracle InForm application.
- Controls the language of Cognos commands and navigation controls.
- Controls the language of the study metadata, such as the names of the report topics in the Cognos Reporting tree, for the Trial Management data model.
Review schema locale
- Set automatically when you deploy your study to the Oracle InForm application.
You can use thePFAdmin
utility to change the review schema locale after the Reporting and Analysis installation. For more information, see the Study and Reporting Setup Guide. - Defines the language in which language-dependent resources such as clinical data
are displayed.
Make sure that the review schema locale that you select for the Reporting and Analysis module contains all the forms and data elements from all the study locales for the study.
Parent topic: The Reporting and Analysis database
