InForm Reporting Database Schema Guide Reporting Data Extracts (RDEs) Creating a custom RDE Running the customization script Running the customization script Open a Command Prompt window. Navigate to the directory where you saved the customization script. Log in to SQL Plus as the study database user. Run the customization SQL file. For example, @MyCustomizeRDE.sql. At SQL Plus, run the following command: exec RD_VIEWS_GEN.GenerateRDViews; Parent topic: Creating a custom RDE
