Study Info: Study Versions
Study Info: Study Versions reporting elements allow you to report on data about the particular study versions.
| Report element | Description |
| Version |
Data type: String Description: The name that is associated with a given study version, as specified in the study design code. This report element returns all study versions. Data source: Replicated from the Oracle InForm transactional database to the Reporting and Analysis database. |
| Version Date |
Data type: Date/Time Description: The date the study version was defined for the study. Date type: May be specified in study design code. If not, this is a system date. |
| Description |
Data type: String Description: Text that describes what has changed in the study version. Study version description text is unique to each study version. Often, this field is used to reflect the iteration of a particular study. For example, a 2 in this field may indicate that the study version is the second revision. Data source: Replicated from the Oracle InForm transactional database to the Reporting and Analysis database. |
| Design Note |
Data type: String Description: Optional notes for the study version entered in the study design code. Data source: Replicated from the Oracle InForm transactional database to the Reporting and Analysis database. |
| Sponsor Approval Date |
Data type: Date/Time Description: The projected date on which the sponsor approved the Oracle InForm study version. This date is set by the study designer. It does not necessarily reflect the actual date the study version goes live. Date type: Specified in study design code. |
Parent topic: Study Info report elements
