If you want to use https to connect to the server, select the Use
Https checkbox.
Select f5cert if you want to use f5cert. The certificate
must be installed on your local machine and you must provide the certificate
subject in the application configuration file.
<add key="IACertName" value="the subject name of the certificate
to sign the soap message" />
In the Virtual Directory field, provide the path or directory on the server.
For example:
pfst62/informadapter
If you are using Username authentication, select the
Enabled checkbox, and fill in the Trial
User and Trial Password fields. Skip this
step if you are using f5cert.
In the Trial Name field, enter the trial to connect to. For example:
