- Sampler Guide for InForm Adapter
- ODM Sampler tool
- Downloading admin data, metadata, and patient data
ODM Export method Steps DownloadAdminData Click DownloadAdminData. In the results pane, response XML for DownloadAdminData appears in a separate tab.
GetSiteList Click GetSiteList. A list of site numbers and names appears, and in the results pane, response XML for GetSiteList appears in a separate tab.
The calls using F5 with certificates are provided to prove that the calls to Oracle Life Sciences InForm Adapter are successful.DownloadMetadata Click DownloadMetadata. In the results pane, response XML for DownloadMetadata appears in a separate tab.
GetPatientList - Click GetSiteList.
- Select a site.
- Click GetPatientList.
A list of patient initials and numbers appears, and in the results pane, the response XML for GetPatientList appears in a separate tab.
GetPatientForms - Click GetSiteList.
- Select a site.
- Select a patient.
- Click GetPatientForms.
A list of forms appears, and in the results pane, the response XML for GetPatientForms appears in a separate tab.
This sample application does not handle transactions that don't satisfy the client-side filters, such as SV subject pool transactions.
Parent topic: ODM Sampler tool
