How can I get more help with HS Learn?
Contact Oracle Life Sciences Support
If you have any additional issues specific to HS Learn, and you need more help, contact Oracle Life Sciences Support using the following URL: https://hsgbu.custhelp.com
Create a ticket, if necessary, for help with a specific issue
If you can't find the help you need in Oracle Life Sciences Support, and you decide to create a support ticket, make sure the following fields are populated with the correct values:
- Product = HS Learn
Product = HS Learn - Issue Category = Training Courses
Parent topic: HS Learn training FAQs
