Installation Guide Install Oracle Life Sciences Data Hub Add clovi.gif to the EBS R12.2 File System Add clovi.gif to the EBS R12.2 File System Source the PATCH file system environment file from the Oracle LSH application server by using the following command:source /<BASE_LOCATION>/EBSapps.env PATCH Perform the following: Note: Ensure that the destination path where you copy the clovi.gif is correct. Copy clovi.gif from $CDR_TOP/media to $RUN_BASE/FMW_Home/Oracle_EBS-app1/applications/oacore/html/cabo/images/cache. Copy clovi.gif from $CDR_TOP/media to $PATCH_BASE/FMW_Home/Oracle_EBS-app1/applications/oacore/html/cabo/images/cache. Re-source the environment file, as required. Parent topic: Install Oracle Life Sciences Data Hub
