Apply the Oracle Life Sciences Data Hub AD Splicer Patch
Because Oracle LSH is off-cycle from the rest of Oracle Applications, you must use the Applications DBA AD Splicer. You must apply the AD Splicer patch for Oracle LSH, patch number 6114439, which is on the Oracle LSH media pack, before you apply the Oracle LSH patch.
Follow instructions in the readme file on how to splice Oracle LSH into your Oracle Applications instance using the AD Splicer.
The readme file currently contains contradictory information about how to apply the patch, saying first to use the AD Splicer and not Autopatch, and later saying to apply the driver using Autopatch. Use only the AD Splicer. Do not apply the unified driver using Autopatch as it says at the end.
For information on the AD Splicer utility, see the section on the AD Splicer in Creating a Custom Application in Oracle E-Business Suite Release 12.1.3 and above (Doc ID 1577707.1).
Ensure to synchronize the run and patch file systems. To do so, execute the following command:
adop phase=fs_clone
For more information, see File System Synchronization Options.
Parent topic: Install Oracle Life Sciences Data Hub
