Clone the Environment (Optional)
Make sure you have installed all the pre-required patches and completed the preclone activities before freezing the system for the cloning propose.
Before cloning the environment, it is recommended to run a full ADOP cycle to make sure the system can switch files systems twice (for example: fs1 > fs2 and fs2 > fs1).
If you plan to create another Oracle LSH environment on the same platform, you can clone your installation at this point. You cannot clone it after you have installed TMS or iAD. Refer to My Oracle Support article 2560690.1, Cloning Oracle E-Business Suite Release 12.1 with Multitenant Database using Rapid Clone.
