Integrate Oracle Clinical with the Oracle Life Sciences Data Hub
Oracle LSH 3.4.1 is compatible with Oracle Clinical 5.4.1 applied.
Oracle LSH includes a set of adapters custom-designed for the purpose of loading data and metadata from Oracle Clinical into Oracle LSH.
To load data and metadata from Oracle Clinical into Oracle LSH you must do the following:
  1. In the Oracle LSH user interface, define a remote location and connection to each Oracle Clinical location from which you want to load data. See "Registering Locations and Connections" in the Oracle Life Sciences Data Hub Administrator's Guide for further information.
  2. Define, check in, install, and run one or more Oracle Clinical Load Sets in Oracle LSH. See "Defining Load Sets" in the Oracle Life Sciences Data Hub Application Developer's Guide for further information.
    You can also use APIs to create Load Sets. These packages are documented in the Oracle Life Sciences Data Hub Application Programming Interface Guide.
