SAS Compatibility
SAS with connectivity to Oracle LSH requires an Oracle 19 c library. Oracle recommends that the Oracle 19 c Client reside on the same server computer as the SAS installation.
To install Oracle LSH and SAS as a processing engine on the same computer:
- Create a 19 c Oracle Home by installing the Oracle Client 19 c.
- Install SAS.
- Set the UNIX environment variable LD_LIBRARY_PATH to the 19c $ORACLE_HOME/lib.
Parent topic: Integrate SAS with the Oracle Life Sciences Data Hub
