PreviousNext
JavaScript must be enabled to correctly display this content
Monitor the Secure File Migration of
CDR_OUTPUT_BLOBS
Make sure at least two DBMS SCHEDULER JOBS are scheduled and running.
These jobs name starts with MIGRATE_BASICFILE_TO_SECUREFILE. Execute the
following command to confirm:
select
owner,
job_name,
JOB_ACTION,
START_DATE,
ENABLED,
STATE
from dba_SCHEDULER_JOBS
where job_name like 'MIGRATE_BASICFILE_TO_SECUREFILE%';
Wait for the BASIC FILE to SECUREFILE migration to complete. You can monitor
the migration progress by executing the following command:
select
thread_id,
Number_of_batch_to_processe,
no_of_processed_batch,
case when THREAD_ID in (1,2) then 'DBMS JOB SHOULD BE RUNNING'
when Number_of_batch_to_processe > no_of_processed_batch then 'DBMS JOB SHOULD BE RUNNING'
else 'DBMS JOB SHOULD NOT BE RUNNING' end as status
from
select thread_id,
count(distinct batchid) Number_of_batch_to_processe,
select count(1)
from CDR_OUTPUT_BLOBS_SFM_TMP
where THREAD_ID=a.THREAD_ID
and status in ('COMPLETE','FAILED')
)no_of_processed_batch
from CDR_OUTPUT_BLOBS_SFM_TMP a
group by thread_id
