Run the Post-Installation Programs
You must run the Oracle LSH LOB Loader and post-installation concurrent programs.
If you are using RAC, shut down all but one database node before running the post-installation programs. If you leave more than one node up, the jobs may run successfully but you may get errors.- Log On to Oracle Applications
- Load the Adapter Files
- Run the Post-Installation Concurrent Program
- Grant Security Rights to Seeded Adapters
- Remove EBS Audit and Create New Auditing Process
- Configure Automated Workarea Tablespace Creation
Configuration required to enable the automated workarea tablespace creation.
Parent topic: Upgrade to Oracle LSH 3.4.2
