Installation Guide Installing Oracle Life Sciences Data Hub Set Up the Distributed Processing Server Copy and Edit Files Copy and Edit Files This section contains the following topics: Copy DP Server Files Edit the DP Server Start Script Make Scripts Executable Copy RTF Template Files for XML Publisher Copy, Edit, and Grant Permissions to Execution Command Files for Processing Engines Parent topic: Set Up the Distributed Processing Server
