Installation Guide Installing Oracle Life Sciences Data Hub Provide Required Grants to the APPS Schema Provide Required Grants to the APPS Schema Connect to the PDB as sys user and execute the following commands: grant execute any procedure to apps with admin option; grant select any dictionary to apps; grant administer database trigger to apps; grant create table, create procedure to apps with admin option; Parent topic: Installing Oracle Life Sciences Data Hub
