Installation Guide Upgrading to Oracle LSH Release 3.4 Set Up the Distributed Processing Server Start the Message Queue Start the Message Queue Connect to PDB as apps user. Make sure the queue is stopped. View the log: select MESSAGE from cdr_msg_queues_log order by log_message_id; If the most recent statement is the following, the queue is stopped.End Procedure cdr_exe_msg_submission.process_queues() If not, stop the queue:begin cdr_exe_msg_queues_admin.stop_processing_queues; end; / Wait until you see the "End Procedure" statement in the log. After the queue is stopped, start and enable the queue: begin cdr_exe_msg_queues_admin.start_processing_queues; cdr_exe_msg_queues_admin.enable_job_processing_queue; end; / Check that the queue is started and enabled: select MESSAGE from cdr_msg_queues_log order by log_message_id; The output should contain the following statements (there may be Submission statements after these):Begin Procedure cdr_exe_msg_submission.process_queues() dequeued from control Q: _MSGCONTROL_ENABLE Parent topic: Set Up the Distributed Processing Server
