Post-Upgrade Database Tasks
Perform the following tasks in Oracle Database 19c:
  • Apply patch 32940955, if not already applied.
  • Set the following values:
    • SGA_MAX_SIZE = 126 GB (after checking free huge pages)
    • SHARED_POOL_SIZE = 26 GB (at the CDB level)
    • Reset the SHARED_POOL_SIZE to 0 (at the PDB level) by executing the following command from PDB:
      alter system reset shared_pool_size scope=both;
  • Execute the following commands:
    alter session set container="CDB$ROOT"
    alter system set "_gc_persistent_read_mostly"=false scope=spfile;
  • Log in as apps account and execute the following script:
    SET serveroutput ON
    declare
      status1 boolean;
    begin
      status1 := cdr_profiles_pkg.SAVE
    ('DMW:Set Based Processing Enabled','$YESNO$NO','SITE');
      if status1 then
       dbms_output.put_line('Success');
      else
       dbms_output.put_line('Failure');
      end if;
    end;
    commit;
    Make sure that executing the following query returns the result as $YESNO$NO:
    select cdr_profiles_pkg.value
    ('DMW:Set Based Processing Enabled') from dual;
    If the result of the query is not $YESNO$NO, contact Life Sciences Support.
  • Grant DME_ERR_LOG to the workarea schemas:
    1. Copy the file $CDR_TOP/patch/115/sql/dmeCrDmeErrTabLSH.sql to a download directory.
    2. Log in to SQL*Plus as the APPS database user.
    3. Execute the script from the download directory:
      <download_directory>/dmeCrDmeErrTabLSH.sql
      The script creates the local DME_ERR_LOG table in all the Oracle LSH work areas that are not connected to any Oracle DMW study.
