Simplify worklist management using views
For a better overview of your tasks, you can switch between views of the Intake Worklist.
The options visible to you may change depending on your role:
Table 5-1 List of Intake Worklist views
| Views | Applicable User Role | Description |
| All | Workflow Manager |
Lists all the intake records, regardless of the assignment. As a workflow manager, this will be your default view when you log in for the first time. |
| Assigned to Group | Workflow Manager, Intake Processor | Lists the intake records that are:
| Assigned to Me | Workflow Manager, Intake Processor |
Lists the intake records that are assigned to you. As an intake processor, this will be your default view when you log in for the first time. |
Parent topic: Working with the Intake Worklist
