Switch between enterprises
Oracle Safety One Intake offers the capability for users to work across several enterprises, all at once.
Each enterprise can be configured separately, with its own set of permissions for users, user groups, and intake records, as well as AE document interpretation method.
As a workflow manager, you can switch between enterprises and work as you would normally, without losing progress on either enterprise you have access to. Each enterprise has its own set of associated records and configurations. Administrators can also set up new enterprises or copy enterprise configurations.
Whenever you switch between enterprises, what you see in the Intake Worklist and the Intake Monitor changes.
The enterprises are listed alphabetically. Should you have access to more than 10 enterprises, an enterprise browser with search capabilities is available.
Preferences such as applied filters, your search history, filter suggestions, or your column settings are saved for each of the enterprises you have access to.
  1. On the upper right-hand side of the page, select the Navigation menu Navigation menu.
  2. Select Switch Enterprise, then select the enterprise environment you would like to change to.
    This menu item will not be available unless you have access to at least two enterprises.
