View dependencies and triggers
Some artifacts shouldn't be started until others reach a specified state. On the Dependencies tab, you'll see all artifacts that are prerequisites for others. The grid shows you the prerequisite artifact's name and the required activity (e.g., complete, upload, etc.). You'll also see the successor (downstream) artifact and activity.
You can filter, search, and sort the Dependencies grid to easily locate a specific dependency at the study or country level. Use the filters to the right of the search field to refine the list. For instance, select All, Study, All Countries, or a specific country and/or dependency state (e.g., Active, Changed, Deleted) filters. Use the search field to locate dependencies by one or more comma-separated keywords. Click any column header to sort the column and further refine the grid display.
- Select one or more dependency rows in the grid and then click the Triggers tab above the grid to see a list of items that, when they occur, cause collection for other items to run.
- Edit (
) or delete (
) a dependency; click the appropriate icon under the Actions column in the grid
- If you need to associate one or more dependencies with one or more countries, you can do that after you select the dependency rows and choose Bulk Country Association from the Actions drop-down menu.
Parent topic: View and change configurations
