Reverse PI replacement
When appropriate you can reinstate a Principal Investigator and save time by using data already saved for that investigator instead of manually recreating the data.
- On the site details page, click the Staff tab.
- Next to the replaced PI's name, click Actions and select Reinstate PI.
- In the confirmation dialog, click Confirm.
When confirmed, the following reinstatement behaviors apply:
- Documents for the reinstated PI that were marked as "For replaced PI" will be marked as “Active.”
- The PI being replaced (by the reinstated PI) will go through the normal PI replacement process, and documents associated with the replaced PI will be marked as “For replaced PI.”
- On the Staff tab, the reinstated PI is marked as “Active” with the original Added date, and the replaced PI will be marked as replaced.
