Enable/disable automatic document distribution from library
When this feature is enabled for the account, you can save time and effort by enabling automatic document distribution in study library. This optional, document-specific setting allows enabled documents to be shared automatically with newly added study countries and sites.
- Click Study library in the global navigation bar.
- On the Share tab, use the filters and search field to locate the document you want to enable for automatic sharing. In the document's Auto-share column, click the enable/disable toggle.
- If auto-share is available, a share document modal opens. Confirm the auto-share toggle is enabled (blue state is enabled, gray state is disabled), and click Share.
- On the confirmation modal, click Confirm.
