Configuring editable system configuration options for trials on the trial level
The Editable System Config Options section lets you configure editable system configuration options for a selected trial.
  1. Select Configuration from the menu bar.
  2. Select the sponsor company and trial from the Current Sponsor Company and Trial drop-down lists.
  3. Enter the settings required.
    The Product Locale is the language—English or Japanese—of the product user interface. Menus, controls, commands, system screen labels, error messages, and so on are written in the selected language. Oracle creates product locales.
  4. Enter the reason for modifying the settings in the Comments field, and click Submit.
  5. To discard the changes, click Return.
