Cluster Review, Approve, and Adjust
The approval step is the last step after the review and any manual overrides for the scenario are completed. The scenario results are a set of clusters that are effective for a merchandise, location, and calendar combination. The batch export process selects the last updated approved cluster to deploy to the subscribing applications using an interface file. You can reject an already approved cluster and deploy it if the selected scenario results are better. You are notified of any manual overrides in which approved clusters are modified. They are automatically redeployed.
Figure 4-43 Cluster Review, Approve, and Adjust
Description of "Figure 4-43 Cluster Review, Approve, and Adjust"
