Segment By Primary Scenario
You see this when you select Segment by in the Criteria panel when you are setting the segment criteria parameters or when you select Segment by in the contextual area for the hierarchy.
The system displays the primary scenario, its preconfigured properties, and the significant attributes identified during the attribute importance process for each segment by.
The following information is displayed.
Table 5-11 Primary Scenario
| Property | Description |
Name |
The name of the primary scenario. |
Status |
Created, Ready for Preview, Ready for Approval, Completed with Errors, Approved, Rejected. |
Maximum # segments |
The maximum number of segments. The default value is 20. This is used for analyzing the segments. |
Minimum # segments |
The minimum number of segments. The default value is 1. This is used for analyzing the segments. |
Attribute |
A list of the attributes configured during segmentation. |
Attribute importance |
The weighted average across attributes and importance index for each attribute. |
