Top Categories
Use this pop-up to select top categories by reviewing category KPIs, such as Sales Share, Revenue, and Margin. The system selects the top categories by each department. You can override these top categories further while defining versions for merchandise. By default, the top categories in the selected merchandise are driven based on the sales share for each category. You can remove categories to reduce processing time and storage, using the user interface and adding emerging to the top category list.
Version Status
The version status has one of the following values.
Table 5-4 Version Status
Status Description
Version Setup Complete
Indicates that version setup is complete.
Filtering Completed with Errors
Indicates that version filtering has completed with errors.
Filtering Execution in Progress
Indicates that version filtering is in progress.
Filtering Completed Successfully
Indicates that version filtering has completed successfully.
Sampling Completed with Errors
Indicates that sampling has completed with errors.
Sampling Execution in Progress
Indicates that sampling execution is in progress.
Sampling Completed Successfully
Indicates that sampling has completed successfully.
Attribute Mining Completed with Errors
Indicates that attribute mining has completed with errors.
Attribute Mining Execution in Progress
Indicates that attribute mining execution is in progress.
Attribute Mining Completed Successfully
Indicates that attribute mining has completed successfully.
Version Ready for Use
Indicates that all three execution phases (filtering, sampling, and attribute mining) have completed successfully. Once the version is ready for use, it is ready for the creation of segment criteria.
