3 RAP Integration
Planning Solutions built on Planning Data Schema (PDS) can be integrated with AI Foundation (AIF) and Retail Insights (RI) with in Retail Analytics and Planning (RAP) using RAP integration which in turn can get the foundation data from RMFCS or any other systems integrated to RAP. All three solutions (AIF, RI, PDS) within RAP can share data using RAP Data Exchange (RDX) using RAP interfaces.
Planning Solutions, such as MFP, configured and built in PDS using the RPASCE Configuration allows configurable solutions if they are not using template to use their custom hierarchy and fact names. Planning Solutions, such as MFP, allow configuring of interfaces using interface.cfg which controls the mapping of dimensions and facts to columns in the RAP interface staging tables. For more details about configuring interfaces using interfaces.cfg in RAP integration, see the Oracle Retail Predictive Application Server Cloud Edition Implementation Guide. The MFP template version has a pre-configured interface.cfg which contains the mapping of interfaces.
This figure shows the RAP integration.
The above diagram shows the high-level RAP Architecture. The customer can upload their main input files as RAP Inbound Data using Object Storage and from their Planning Applications deployed in PDS can get the same using RDX. For more details about the RAP Inbound Interfaces, see the Oracle Retail Analytics and Planning Implementation Guide. Any supplemental data that is specific to planning can be directly loaded into PDS as PDS Flat Files. This section shows the details about the interfaces used by PDS in RAP using RDX.
Following are the pre-defined grouping of interfaces available in the MFP template version within RAP integration:
  • Foundation and Transactional data from RMFCS using Retail Insights (RI)
  • Plan Exports to Retail Insights (RI)
  • Forecast Imports from AI Foundation (AIF)
Foundation and Transactional Data from RMFCS using Retail Insights
RMFCS can send Foundation and Transactional data to RAP integration using Retail Insights (RI) and other systems within RAP. The systems can share the data, even if RMFCS is not implemented for the customer. The customer can upload the foundation and data files in the file format needed by RI in RAP integration. That way, the same data can be published to all applications within RAP. It can be done by scheduling required job flows in Retail Insights to get the foundation data from RMFCS and loading it into the staging tables present in Retail Data Exchange (RDX) from where the configured interfaces in MFP can pull the required data into Facts in Planning Data Schema (PDS) where MFP is deployed.
The customer can also load foundation data directly into RAP using the file format specified for RAP integration and using the same staging process in RI to write the data into RDX staging tables from where Planning can pull the data using standard configured interfaces. Only mapped columns specific to GA interfaces are detailed in this guide. For more details about interface file formats and the jobs flow details, see the Oracle Retail Analytics and Planning Implementation Guide. Also refer to those guides to find more information about the available columns in each interface staging tables in RDX sourced from RI so that customers using extensibility on template or using custom configuration (non-template) can pull the required data from RDX.
For information about the mappings between the columns in RDX interface table and RAP Inbound Data File columns, see the Data Mappings in the Transformations from RI to Planning section of the Oracle Retail Analytics and Planning Implementation Guide. The following sections shows the mappings between the RDX Interface table columns and the measures and dimensions in Planning.
The following table shows the list of interfaces in RAP to get the foundation and transactional data:
Interface Interface and Table Name Interface Type
Product Hierarchy
W_PDS_PRODUCT_D
Hierarchy Importer
Location Hierarchy
W_PDS_ORGANIZATION_D
Hierarchy Importer
Calendar Hierarchy
W_PDS_CALENDAR_D (VW_CLND_HIER)
Hierarchy Importer
Currency Hierarchy
VW_CURR_HIER (W_PDS_EXCH_RATE_D)
Hierarchy Importer
Sales Interface
W_PDS_SLS_IT_LC_WK_A
Data Importer
Inventory Interface
W_PDS_INV_IT_LC_WK_A
Data Importer
Markdown Interface
W_PDS_MKDN_IT_LC_WK_A
Data Importer
On Order Interface
W_PDS_PO_ONORD_IT_LC_WK_A
Data Importer
Receipts Interface
W_PDS_INVRC_IT_LC_WK_A
Data Importer
Inventory Adjustments
W_PDS_INVADJ_IT_LC_WK_A
Data Importer
Inventory Transfers
W_PDS_INVTSF_IT_LC_WK_A
Data Importer
Deal Incomes
W_PDS_DEALINC_IT_LC_WK_A
Data Importer
Wholesale/Franchise
W_PDS_SLSWF_IT_LC_WK_A
Data Importer
Currency Conversion Rates
W_PDS_EXCH_RATE_D (VW_CURR_RATE)
Data Importer
Location Data
VW_LOC_DATA
Data Importer
The following table shows the mapping of dimensions to columns for Hierarchy Importer interfaces from external interface tables:
Hierarchy Dimension External Interface Table External Mapped Column
prod
sku
W_PDS_PRODUCT_D
ITEM
prod
sku_label
W_PDS_PRODUCT_D
ITEM_DESC
prod skup
W_PDS_PRODUCT_D
ITEM_PARENT_DIFF
prod skup_label
W_PDS_PRODUCT_D
ITEM_PARENT_DIFF_DESC
prod skug
W_PDS_PRODUCT_D
ITEM_PARENT
prod skug_label
W_PDS_PRODUCT_D
ITEM_PARENT_DESC
prod
scls
W_PDS_PRODUCT_D
CLASS_ID
prod
scls_label
W_PDS_PRODUCT_D
DEPT
prod
clss
W_PDS_PRODUCT_D
GROUP_NO
prod
class_label
W_PDS_PRODUCT_D
DIVISION
prod
dept
W_PDS_PRODUCT_D
COMPANY
prod
dept_label
W_PDS_PRODUCT_D
CO_NAME
prod
pgrp
W_PDS_PRODUCT_D
GROUP_NO
prod
pgrp_label
W_PDS_PRODUCT_D
GROUP_NAME
prod
dvsn
W_PDS_PRODUCT_D
DIVISION
prod
dvsn_label
W_PDS_PRODUCT_D
DIV_NAME
prod
cmpp
W_PDS_PRODUCT_D
COMPANY
prod
cmpp_label
W_PDS_PRODUCT_D
CO_NAME
loc
stor
LOCATION
loc
stor_label
LOC_NAME
loc
dstr
DISTRICT
loc
dstr_label
DISTRICT_NAME
loc
regn
REGION
loc
regn_label
REGION_NAME
loc
chnl
AREA
loc
chnl_label
AREA_NAME
loc
chan
CHAIN
loc
chan_label
CHAIN_NAME
loc
comp
COMPANY
loc
comp_label
CO_NAME
loc
phwh
PHYSICAL_WH
loc
phwh_label
PHYSICAL_WH_NAME
loc
loct
LOC_TYPE
loc
loct_label
LOC_TYPE_NAME
loc
strc
LOCATION
loc
strc_label
LOC_NAME
loc
chnc
PLANNING_CHANNEL_ID
loc
chnc_label
PLANNING_CHANNEL_NAME
loc
ccty
PLANNING_COUNTRY_ID
loc
ccty_label
PLANNING_COUNTRY_NAME
clnd
day
W_PDS_CALENDAR_D
DAY
clnd
day_label
W_PDS_CALENDAR_D
DAY_LABEL
clnd
week
W_PDS_CALENDAR_D
WEEK
clnd
week_label
W_PDS_CALENDAR_D
WEEK_LABEL
clnd
mnth
W_PDS_CALENDAR_D
MNTH
clnd
mnth_label
W_PDS_CALENDAR_D
MNTH_LABEL
clnd
qrtr
W_PDS_CALENDAR_D
QRTR
clnd
qrtr_label
W_PDS_CALENDAR_D
QRTR_LABEL
clnd
half
W_PDS_CALENDAR_D
HALF
clnd
half_label
W_PDS_CALENDAR_D
HALF_LABEL
clnd
year
W_PDS_CALENDAR_D
YEAR
clnd
year_label
W_PDS_CALENDAR_D
YEAR_LABEL
clnd
woyr
W_PDS_CALENDAR_D
WOYR
clnd
woyr_label
W_PDS_CALENDAR_D
WOYR_LABEL
clnd
stdb
W_PDS_CALENDAR_D
STDB
curh
curc
VW_CURR_HIER
TO_CURRENCY_CODE
curh
curc_label
VW_CURR_HIER
TO_CURRENCY_CODE
satr satt VW_SATR_HIER ATTR_ID
satr satt_label VW_SATR_HIER ATTR_DESC
satr satv VW_SATR_HIER ATTR_VALUE
satr satv_label VW_SATR_HIER ATTR_VALUE_DESC
Note: For Calendar Hierarchy (clnd), RMFCS is not sending the labels. Internally, VW_CLND_HIER is defined in PDS against the interface W_PDS_CALENDAR_D table to derive the labels and also default the calendar import to PDS to have two past years, one current year, and two future years based on the current business date. The Administrator can update the same using the Online Administration Tool Tasks under System Admin Tasks -> List/Set/Unset PDS Integration variables and can update the CLND_PAST_YEARS and CLND_FUTURE_YEARS variables. By default, both are set to 2. The customer can also update the start fiscal month by setting the CLND_START_MONTH variable. By default, it is set to 2 to have the fiscal start month label be generated as February.
Note: For Currency Hierarchy (curh), there is no direct interface table. Internally, VW_CURR_HIER is defined in PDS against the interface W_PDS_EXCH_RATE_G table to get the unique currency codes. The base currency code is set by default as USD to get the conversion rates for other currencies. The Administrator can update the same using the Online Administration Tool Tasks under System Admin Tasks -> List/Set/Unset PDS Integration variables and can update the BASE_CURRENCY_CODE.
Note: For the Location Attribute Hierarchy (SATR), there is no direct interface table. Internally, VW_SATR_HIER is defined in PDS against the interface W_PDS_ORG_ATTR_STR_D table to get the distinct location attributes.
Note: The VAT Hierarchy (vath) in the MFP GA is not integrated using RAP integration. The customer needs to explicitly provide those files for the MFP GA.
The following table shows the mapping of fact names/measures names to columns for the Data Importer interfaces from the external interface tables in RDX:
Fact Name External Interface Table External Mapped Column External Mapping Condition
drtyeop1c
REGULAR_INVENTORY_COST
CLEAR_IND = 'N'
drtyeop1r
REGULAR_INVENTORY_RETAIL
CLEAR_IND = 'N'
drtyeop1u
REGULAR_INVENTORY_UNITS
CLEAR_IND = 'N'
drtyeop2c
CLEAR_IND = 'Y'
drtyeop2r
CLEAR_IND = 'Y'
drtyeop2u
CLEAR_IND = 'Y'
drtyrinva1c
SHRINK_COST
drtyrinva1r
SHRINK_RETAIL
drtyrinva1u
SHRINK_UNITS
drtyrinva2c
NON_SHRINK_ADJ_COST
drtyrinva2r
NON_SHRINK_ADJ_RETAIL
drtyrinva2u
NON_SHRINK_ADJ_UNITS
drtymkdcanr
MARKDOWN_CANCEL
drtymkdclrr
CLEAR_MARKDOWN_RETAIL
drtymkdpclr
PROMO_MARKDOWN_RETAIL_CLEAR
drtymkdpror
PROMO_MARKDOWN_RETAIL_REG
drtymkdregr
REG_MARKDOWN_RETAIL
drtymkupr
MARKUP
drtyicmkur
INTERCOMPANY_MARKUP
drtyicmkdr
INTERCOMPANY_MARKDOWN
drtywfmkdr
WF_MARKDOWN_RETAIL
drtywfmkur
WF_MARKUP_RETAIL
drtywfslsu
FRANCHISE_SALES_UNITS
drtywfslsc
FRANCHISE_SALES_COST
drtywfslsr
FRANCHISE_SALES_RETAIL
drtywfrtnu
FRANCHISE_RETURNS_UNITS
drtywfrtnc
FRANCHISE_RETURNS_COST
drtywfrtnr
FRANCHISE_RETURNS_RETAIL
drtynslsclrc
NET_SALES_CLR_COST
drtynslsclrr
NET_SALES_CLR_RETAIL
drtynslsclru
NET_SALES_CLR_UNITS
drtynslsproc
NET_SALES_PRO_COST
drtynslspror
NET_SALES_PRO_RETAIL
drtynslsprou
NET_SALES_PRO_UNITS
drtynslsregc
NET_SALES_REG_COST
drtynslsregr
NET_SALES_REG_RETAIL
drtynslsregu
NET_SALES_REG_UNITS
drtyrtnclrc
RETURNS_CLR_COST
drtyrtnclrr
RETURNS_CLR_RETAIL
drtyrtnclru
RETURNS_CLR_UNITS
drtyrtnproc
RETURNS_PRO_COST
drtyrtnpror
RETURNS_PRO_RETAIL
drtyrtnprou
RETURNS_PRO_UNITS
drtyrtnregc
RETURNS_REG_COST
drtyrtnregr
RETURNS_REG_RETAIL
drtyrtnregu
RETURNS_REG_UNITS
drtyooc
ON_ORDER_COST
drtyoor
ON_ORDER_RETAIL
drtyoou
ON_ORDER_UNITS
drtyporcptc
PO_RECEIPT_COST
drtyporcptr
PO_RECEIPT_RETAIL
drtyporcptu
PO_RECEIPT_UNITS
drtytraninbc
TSF_IN_COST
TSF_TYPE = 'B'
drtytraninbr
TSF_IN_RETAIL
TSF_TYPE = 'B'
drtytraninbu
TSF_IN_UNITS
TSF_TYPE = 'B'
drtytraninic
TSF_IN_COST
TSF_TYPE = 'I'
drtytraninir
TSF_IN_RETAIL
TSF_TYPE = 'I'
drtytraniniu
TSF_IN_UNITS
TSF_TYPE = 'I'
drtytraninr
TSF_IN_RETAIL
TSF_TYPE = 'N'
drtytraninc
TSF_IN_COST
TSF_TYPE = 'N'
drtytraninu
TSF_IN_UNITS
TSF_TYPE = 'N'
drtytranoutbc
TSF_OUT_COST
TSF_TYPE = 'B'
drtytranoutbr
TSF_OUT_RETAIL
TSF_TYPE = 'B'
drtytranoutbu
TSF_OUT_UNITS
TSF_TYPE = 'B'
drtytranoutic
TSF_OUT_COST
TSF_TYPE = 'I'
drtytranoutir
TSF_OUT_RETAIL
TSF_TYPE = 'I'
drtytranoutiu
TSF_OUT_UNITS
TSF_TYPE = 'I'
drtytranoutr
TSF_OUT_RETAIL
TSF_TYPE = 'N'
drtytranoutu
TSF_OUT_UNITS
TSF_TYPE = 'N'
drtytranoutc
TSF_OUT_COST
TSF_TYPE = 'N'
drtyvndfndr
DEAL_INCOME_SALES
addvlocopnd
VW_LOC_DATA
STORE_OPEN_DATE
addvlocendd
VW_LOC_DATA
STORE_CLOSE_DATE
addvlocrefd
VW_LOC_DATA
REMODEL_DATE
addvwfpoct
VW_LOC_DATA
STORE_TYPE
drtylcratex
W_PDS_EXCH_RATE_G
EXCHANGE_RATE
addvlocatt W_PDS_ORG_ATTR_STR_D ATTR_VALUE
Note: For Location specific data, the same W_PDS_ORGANIZATION_D hierarchy table used for the location hierarchy is used. The view VW_LOC_DATA is defined in PDS to point to the same set of data and used as data importer interface.
Note: Pack Items are filtered by default for MFP during the product hierarchy import from RAP using the Pack Item Filter Value measure set to N. This shared filter measure, PCKFLGVAL, can be managed in the Planning Admin workbook. In a multi-app scenario, if other applications need to bring in pack items, this can be changed to % to bring in both pack items and non-pack items.
Approved plans from MFPCS can be exported to Retail Insights within RAP integration. Retail Insights allows getting four levels of plans for different versions. The MFP template version allows creating four levels of plans, Merch Plan (OP, CP), Merch Target (TG), Location Plan (OP, CP), and Location Target Plan (TG). All those plans and their different versions can be exported to Retail Insights on a weekly basis. Since MFP non-template versions can create a different level of plans and also can configure various metrics, the interface staging table in Retail Sights contains the same set of columns and various flex columns.
For more details about the list of columns available in the Retail Insights Interface Staging table if the customer plans to use extensibility or use the non-template version to send additional data, see the Oracle Retail Insights Implementation Guide. This guide contains only the mapped columns for the MFP template version for each level of plans.
The following table shows the list of interfaces in RAP to export the plan data from MFP to RI:
Merch Plan Export
MFP_PLAN1_EXP
Data Explorer
Merch Target Plan Export
MFP_PLAN2_EXP
Data Explorer
Location Plan Export
MFP_PLAN3_EXP
Data Explorer
Location Target Plan Export
MFP_PLAN4_EXP
Data Explorer
Note: If Retail/Cost is denoted, that metric will have value only if that version of MFP is implemented from the template, otherwise that value will be always exported as zero.
Plan Level 1 MFP_PLAN1_EXP - Merch Plan Export
This plan export is for exporting both the OP and CP versions of approved Merch Plans. VERSION_NUM 0 is used to export the OP version and 1 is used to export the CP version. The following table only shows the mapping for OP versions. The CP versions of mapping remain the same; the Version Number used is 1.
Staging Table Column Description MFP Dimension/Measure Mapping Retail/Cost
PROD_KEY
Product Dimension
scls
LOC_KEY
Location Dimension
chnc
CLND_KEY
Calendar Dimension
week
PROD_DH_ATTR
Attribute Dimension for RI
-1
SUPPLIER_NUM
Supplier Dimension for RI
-1
CAL_DATE
Last Day of Week
MPOPLDOWD
VERSION_NUM
Version Number
0
SLS_QTY
Op Sales U
MPOPSlsU
SLSCL_QTY
Op Sales Clr U
MPOPSls2U
SLSRGPRO_QTY
Op Sales Reg+Promo U
MPOPSls1U
SLS_RTL_AMT
Op Sales R
MPOPSlsR
SLSCL_RTL_AMT
Op Sales Clr R
MPOPSls2R
SLSRGPRO_RTL_AMT
Op Sales Reg+Promo R
MPOPSls1R
SLS_COST_AMT
Op Sales C
MPOPSlsC
RET_QTY
Op Returns U
MPOPRtnU
RETCL_QTY
Op Returns Clr U
MPOPRtn2U
RETRGPRO_QTY
Op Returns Reg+Promo U
MPOPRtn1U
RET_RTL_AMT
Op Returns R
MPOPRtnR
RETCL_RTL_AMT
Op Returns Clr R
MPOPRtn2R
RETRGPRO_RTL_AMT
Op Returns Reg+Promo R
MPOPRtn1R
NET_SLSRGPRO_QTY
Op Net Sales Reg+Promo U
MPOPNSls1U
NET_SLSCL_QTY
Op Net Sales Clr U
MPOPNSls2U
NET_SLSRGPRO_RTL_AMT
Op Net Sales Reg+Promo R
MPOPNSls1R
NET_SLSCL_RTL_AMT
Op Net Sales Clr R
MPOPNSls2R
NET_MARGIN_RTL_AMT
Op Net GM R
MPOPNGMR
TAX_RTL_AMT
Op VAT R
MPOPVATR
SLSTE_RTL_AMT
Op Net Sales R
MPOPNSlsR
MARGIN_RTL_AMT
Op GM R
MPOPGMR
MKDNPM_RTL_AMT
Op Inv Devaluation Reg+Promo R
MPOPInvDV1R
MKDNCL_RTL_AMT
Op Inv Devaluation Clr R
MPOPInvDV2R
MKDNPR_RTL_AMT
Op Markdown R
MPOPMkdR
BOH_COST_AMT
Op BOP C
MPOPBOPC
BOH_RTL_AMT
Op BOP R
MPOPBOPR
BOHRGPRO_RTL_AMT
Op BOP Reg+Promo R
MPOPBOP1R
BOHCL_RTL_AMT
Op BOP Clr R
MPOPBOP2R
BOH_QTY
Op BOP U
MPOPBOPU
BOHRGPRO_QTY
Op BOP Reg+Promo U
MPOPBOP1U
BOHCL_QTY
Op BOP Clr U
MPOPBOP2U
EOH_COST_AMT
Op EOP C
MPOPEOPC
EOHRGPRO_COST_AMT
Op EOP Reg+Promo C
MPOPEOP1C
Cost
EOHCL_COST_AMT
Op EOP Clr C
MPOPEOP2C
Cost
EOH_RTL_AMT
Op EOP R
MPOPEOPR
Retail
EOHRGPRO_RTL_AMT
Op EOP Reg+Promo R
MPOPEOP1R
Retail
EOHCL_RTL_AMT
Op EOP Clr R
MPOPEOP2R
Retail
EOH_QTY
Op EOP U
MPOPEOPU
EOHRGPRO_QTY
Op EOP Reg+Promo U
MPOPEOP1U
EOHCL_QTY
Op EOP Clr U
MPOPEOP2U
INVRC_COST_AMT
Op Receipts C
MPOPRcptC
INVRC_RTL_AMT
Op Receipts R
MPOPRcptR
INVRC_QTY
Op Receipts U
MPOPRcptU
INVADJ_COST_AMT
Op Inv Adj C
MPOPInvAdjC
INVADJ_RTL_AMT
Op Inv Adj R
MPOPInvAdjR
INVADJ_QTY
Op Inv Adj U
MPOPInvAdjU
SHRINK_COST_AMT
Op Shrink C
MPOPShrkC
SHRINK_RTL_AMT
Op Shrink R
MPOPShrkR
Retail
SHRINK_QTY
Op Shrink U
MPOPShrkU
MISCI_COST_AMT
Op Misc Adj C
MPOPMiscAdjC
Cost
MISCI_RTL_AMT
Op Misc Adj R
MPOPMiscAdjR
Retail
MISCI_QTY
Op Misc Adj U
MPOPMiscAdjU
MOVETOCL_COST_AMT
Op Move to Clr C
MPOPMOCC
Cost
MOVETOCL_RTL_AMT
Op Move to Clr R
MPOPMOCR
Retail
MOVETOCL_QTY
Op Move to Clr U
MPOPMOCU
MOS_COST_AMT
Op MOS C
MPOPMOSC
MOS_RTL_AMT
Op MOS R
MPOPMOSR
Retail
MOS_QTY
Op MOS U
MPOPMOSU
MKDNWF_RTL_AMT
Op Markdown due to W/F R
MPOPMkdWFR
RYLTY_RTL_AMT
Op Royalties R
MPOPRoyalR
VNDFND_RTL_AMT
Op Vendor Funds R
MPOPVndFndR
DMND_QTY
Op Demand U
MPOPDemandU
DMND_CAN_QTY
Op Cancel U
MPOPCancU
SLS_COMP_RTL_AMT
Op Comp Sales R
MPOPSlsCmpR
SLS_NCOMP_RTL_AMT
Op Non-Comp Sales R
MPOPSlsNCpR
TRAFFIC_CNT
Op Traffic U
MPOPTrafficU
OTB_COST_AMT Wp OTB C MPWPOTBC
OTB_RTL_AMT Wp OTB R MPWPOTBR Retail
OTB_QTY Wp OTB U MPWPOTBU
Plan Level 2 MFP_PLAN2_EXP - Merch Target Plan Export
This plan export is for exporting the Tgt version of approved Merch Target Plans. VERSION_NUM 0 is used to export the Target version.
PROD_KEY
Product Dimension
dept
LOC_KEY
Location Dimension
chnc
CLND_KEY
Calendar Dimension
week
PROD_DH_ATTR
-1
SUPPLIER_NUM
-1
CAL_DATE
Last Day of Week
MTTGLDOWD
VERSION_NUM
Version Number
0
SLS_QTY
Tgt Sales U
MTTGSlsU
SLSCL_QTY
Tgt Sales Clr U
MTTGSls2U
Retail
SLSRGPRO_QTY
Tgt Sales Reg+Promo U
MTTGSls1U
Retail
SLS_RTL_AMT
Tgt Sales R
MTTGSlsR
SLSCL_RTL_AMT
Tgt Sales Clr R
MTTGSls2R
Retail
SLSRGPRO_RTL_AMT
Tgt Sales Reg+Promo R
MTTGSls1R
Retail
SLS_COST_AMT
Tgt Sales C
MTTGSlsC
RET_QTY
Tgt Returns U
MTTGRtnU
RETCL_QTY
Tgt Returns Clr U
MTTGRtn2U
RETRGPRO_QTY
Tgt Returns Reg+Promo U
MTTGRtn1U
RET_RTL_AMT
Tgt Returns R
MTTGRtnR
RETCL_RTL_AMT
Tgt Returns Clr R
MTTGRtn2R
RETRGPRO_RTL_AMT
Tgt Returns Reg+Promo R
MTTGRtn1R
NET_SLSRGPRO_QTY
Tgt Net Sales Reg+Promo U
MTTGNSls1U
NET_SLSCL_QTY
Tgt Net Sales Clr U
MTTGNSls2U
Tgt Net Sales Reg+Promo R
MTTGNSls1R
NET_SLSCL_RTL_AMT
Tgt Net Sales Clr R
MTTGNSls2R
NET_MARGIN_RTL_AMT
Tgt Net GM R
MTTGNGMR
TAX_RTL_AMT
Tgt VAT R
MTTGVATR
SLSTE_RTL_AMT
Tgt Net Sales R
MTTGNSlsR
MARGIN_RTL_AMT
Tgt GM R
MTTGGMR
MKDNPM_RTL_AMT
Tgt Inv Devaluation Reg+Promo R
MTTGInvDV1R
MKDNCL_RTL_AMT
Tgt Inv Devaluation Clr R
MTTGInvDV2R
MKDNPR_RTL_AMT
Tgt Markdown R
MTTGMkdR
BOH_COST_AMT
Tgt BOP C
MTTGBOPC
BOH_RTL_AMT
Tgt BOP R
MTTGBOPR
BOHRGPRO_RTL_AMT
Tgt BOP Reg+Promo R
MTTGBOP1R
BOHCL_RTL_AMT
Tgt BOP Clr R
MTTGBOP2R
BOH_QTY
Tgt BOP U
MTTGBOPU
BOHRGPRO_QTY
Tgt BOP Reg+Promo U
MTTGBOP1U
BOHCL_QTY
Tgt BOP Clr U
MTTGBOP2U
EOH_COST_AMT
Tgt EOP C
MTTGEOPC
EOHRGPRO_COST_AMT
Tgt EOP Reg+Promo C
MTTGEOP1C
EOHCL_COST_AMT
Tgt EOP Clr C
MTTGEOP2C
EOH_RTL_AMT
Tgt EOP R
MTTGEOPR
EOHRGPRO_RTL_AMT
Tgt EOP Reg+Promo R
MTTGEOP1R
EOHCL_RTL_AMT
Tgt EOP Clr R
MTTGEOP2R
EOH_QTY
Tgt EOP U
MTTGEOPU
EOHRGPRO_QTY
Tgt EOP Reg+Promo U
MTTGEOP1U
EOHCL_QTY
Tgt EOP Clr U
MTTGEOP2U
INVRC_COST_AMT
Tgt Receipts C
MTTGRcptC
INVRC_RTL_AMT
Tgt Receipts R
MTTGRcptR
INVRC_QTY
Tgt Receipts U
MTTGRcptU
INVADJ_COST_AMT
Tgt Inv Adj C
MTTGInvAdjC
INVADJ_RTL_AMT
Tgt Inv Adj R
MTTGInvAdjR
Retail
INVADJ_QTY
Tgt Inv Adj U
MTTGInvAdjU
SHRINK_COST_AMT
Tgt Shrink C
MTTGShrkC
SHRINK_RTL_AMT
Tgt Shrink R
MTTGShrkR
Retail
SHRINK_QTY
Tgt Shrink U
MTTGShrkU
MISCI_COST_AMT
Tgt Misc Adj C
MTTGMiscAdjC
MISCI_RTL_AMT
Tgt Misc Adj R
MTTGMiscAdjR
Retail
MISCI_QTY
Tgt Misc Adj U
MTTGMiscAdjU
MOVETOCL_COST_AMT
Tgt Move to Clr C
MTTGMOCC
MOVETOCL_RTL_AMT
Tgt Move to Clr R
MTTGMOCR
Retail
MOVETOCL_QTY
Tgt Move to Clr U
MTTGMOCU
MOS_COST_AMT
Tgt MOS C
MTTGMOSC
MOS_RTL_AMT
Tgt MOS R
MTTGMOSR
Retail
MOS_QTY
Tgt MOS U
MTTGMOSU
MKDNWF_RTL_AMT
Tgt Markdown due to W/F R
MTTGMkdWFR
RYLTY_RTL_AMT
Tgt Royalties R
MTTGRoyalR
VNDFND_RTL_AMT
Tgt Vendor Funds R
MTTGVndFndR
DMND_QTY
Tgt Demand U
MTTGDemandU
DMND_CAN_QTY
Tgt Cancel U
MTTGCancU
SLS_COMP_RTL_AMT
Tgt Comp Sales R
MTTGSlsCmpR
SLS_NCOMP_RTL_AMT
Tgt Non-Comp Sales R
MTTGSlsNCpR
TRAFFIC_CNT
Tgt Traffic U
MTTGTrafficU
OTB_COST_AMT Wp OTB C MTWPOTBC
OTB_RTL_AMT Wp OTB R MTWPOTBR Retail
OTB_QTY Wp OTB U MTWPOTBU
Plan Level 3 MFP_PLAN3_EXP - Location Plan Export
This plan export is for exporting both the OP and CP versions of approved Location Plans. VERSION_NUM 0 is used to export the OP version and 1 is used to export the CP version. The following table only shows the mapping for OP versions. The CP versions of mapping remain the same; the Version Number used is 1.
PROD_KEY
Product Dimension
DEPT
LOC_KEY
Location Dimension
STOR
CLND_KEY
Calendar Dimension
WEEK
PROD_DH_ATTR
-1
SUPPLIER_NUM
-1
CAL_DATE
Last Day of Week
LPOPLDOWD
VERSION_NUM
Version Number
0
SLS_QTY
Op Sales U
LPOPSlsU
SLSCL_QTY
Op Sales Clr U
LPOPSls2U
SLS_RTL_AMT
Op Sales R
LPOPSlsR
SLSCL_RTL_AMT
Op Sales Clr R
LPOPSls2R
SLS_COST_AMT
Op Sales C
LPOPSlsC
RET_QTY
Op Returns U
LPOPRtnU
RETCL_QTY
Op Returns Clr U
LPOPRtn2U
RET_RTL_AMT
Op Returns R
LPOPRtnR
TAX_RTL_AMT
Op VAT R
LPOPVATR
SLSTE_RTL_AMT
Op Net Sales R
LPOPNSlsR
MARGIN_RTL_AMT
Op GM R
LPOPGMR
MKDNPM_RTL_AMT
LPOPInvDVR
MKDNPR_RTL_AMT
Op Markdown R
LPOPMkdR
BOH_COST_AMT
Op BOP C
LPOPBOPC
BOH_RTL_AMT
Op BOP R
LPOPBOPR
Retail
BOH_QTY
Op BOP U
LPOPBOPU
EOH_COST_AMT
Op EOP C
LPOPEOPC
EOH_RTL_AMT
Op EOP R
LPOPEOPR
Retail
EOH_QTY
Op EOP U
LPOPEOPU
INVRC_COST_AMT
Op Receipts C
LPOPRcptC
INVRC_RTL_AMT
Op Receipts R
LPOPRcptR
Retail
INVRC_QTY
Op Receipts U
LPOPRcptU
INVADJ_QTY
Op Inv Adj U
LPOPInvAdjU
SHRINK_COST_AMT
Op Shrink C
LPOPShrkC
SHRINK_RTL_AMT
Op Shrink R
LPOPShrkR
Retail
SHRINK_QTY
Op Shrink U
LPOPShrkU
MKDNWF_RTL_AMT
LPOPMkdWFR
OTB_COST_AMT Wp OTB C LPWPOTBC
OTB_RTL_AMT Wp OTB R LPWPOTBR Retail
OTB_QTY Wp OTB U LPWPOTBU
Plan Level 4 MFP_PLAN4_EXP - Location Target Plan Export
This plan export is for exporting the Tgt version of approved Location Target Plans. VERSION_NUM 0 is used to export the Target version.
PROD_KEY
Product Dimension
DEPT
LOC_KEY
Location Dimension
STOR
CLND_KEY
Calendar Dimension
WEEK
PROD_DH_ATTR
-1
SUPPLIER_NUM
-1
CAL_DATE
Last Day of Week
LTTGLDOWD
VERSION_NUM
Version Number
0
SLS_QTY
Tgt Sales U
LTTGSlsU
SLS_RTL_AMT
Tgt Sales R
LTTGSlsR
RET_QTY
Tgt Returns U
LTTGRtnU
RET_RTL_AMT
Tgt Returns R
LTTGRtnR
MKDNPR_RTL_AMT
Tgt Markdown R
LTTGMkdR
Retail
Forecasts can be generated from AI Foundation (AIF) and imported to MFPCS using RAP integration. AI Foundation can generate different levels of forecasts as needed by different levels of plans. It generates both Pre-Season forecasts (using the Auto-ES Forecast method) and In-Season Forecasts (using the Bayesian Forecast Method). AI Foundation directly gets the actuals and plan data from MFP through RI using RAP integration. Job flows in AI Foundation need to be scheduled to generate the forecast and import the same to MFP. For more details, see the Oracle Retail Analytics and Planning Implementation Guide.
In order to get forecasts from AI Foundation (AIF), during implementation, some initial setups need to be done in the AI Foundation (AIF) platform. For more details, see the Oracle Retail Analytics and Planning Implementation Guide.
The following table shows the interface table column details from AI Foundation in RDX used for the interface.
Interface Name: RSE_FCST_DEMAND_EXP
Table Column Data Type Comments
RUN_ID
Number(10)
The export Run ID as obtained from the RAP_INTF_UTIL.
CAL_HIER_LEVEL
Varchar2(30)
The calendar level data is for Fiscal Year, Fiscal Quarter, Fiscal Period, Fiscal Week, and Fiscal Day.
LOC_HIER_LEVEL
Varchar2(30)
The location hierarchy level data is for COMPANY, CHAIN, AREA, REGION, DISTRICT, LOCATION, and CHANNEL_COUNTRY.
PROD_HIER_LEVEL
Varchar2(30)
The product hierarchy level the data is for CMP, DIV, GRP, DEPT, CLS, SBC, STYLE, STYLE_COLOR, and SKU.
FCST_DATE_FROM
Date
The start date which the forecast is for.
LOC_EXT_KEY
Varchar2(80)
The external id of the location. It will use the integration ids as provided to RI (preferably the RMS id, and not an integration id such as AREA~123).
PROD_EXT_KEY
Varchar2(80)
The external id of the product hierarchy. It will use the integration ids as provided to RI (preferably the RMS id, and not an integration id such as CLS~123~456~789).
CUSTSEG_EXT_KEY
Varchar2(80)
The external id of the customer segment. It will be NULL if not applicable.
FCST_TYPE
Varchar2(20)
The type of forecast. PI, NPI (PI=Plan Influenced, PI = Non Plan Influenced)
REG_SLS_QTY
Number(38,20)
Regular Sales Units
REG_SLS_AMT
Number(38,20)
Regular Sales Amount
PR_SLS_QTY
Number(38,20)
Promo Sales Units
PR_SLS_AMT
Number(38,20)
Promo Sales Amount
CLR_SLS_QTY
Number(38,20)
Clearance Sales Units
CLR_SLS_AMT
Number(38,20)
Clearance Sales Amount
REG_PR_SLS_QTY
Number(38,20)
Regular and Promo Sales Units
REG_PR_SLS_AMT
Number(38,20)
Regular and Promo Sales Amount
SLS_QTY
Number(38,20)
Total Sales Units
SLS_AMT
Number(38,20)
Total Sales Amount
RET_QTY
Number(38,20)
Return Units
RET_AMT
Number(38,20)
Return Amount
The same Interface table contains the forecast data for different levels of plans differentiated by _LEVEL columns within the interface. The single interface run pulls data for different levels of forecasts which are pre-configured. Customers using non-template versions, if using different levels of plans, can use the supported levels in AI Foundation to generate forecasts. The following sections provide the default levels of forecasts exported for the MFPCS template version and their mappings.
Merch Plan Forecasts Mapping
The following table shows the mapping for pre-season and in-season Merch Plan Forecasts.
Table Column Mapping for Pre-Season (MPP) Mapping for In-Season (MPI)
CAL_HIER_LEVEL
Fiscal Week
Fiscal Week
LOC_HIER_LEVEL
CHANNEL_COUNTRY
CHANNEL_COUNTRY
PROD_HIER_LEVEL
SBC
SBC
FCST_DATE_FROM
WEEK
WEEK
LOC_EXT_KEY
CHNL
CHNL
PROD_EXT_KEY
SCLS
SCLS
CUSTSEG_EXT_KEY
NULL
NULL
FCST_TYPE
NPI
PI
CLR_SLS_QTY
MPWPDmdP2U
MPWPDmdI2U
CLR_SLS_AMT
MPWPDmdP2R
MPWPDmdI2R
REG_PR_SLS_QTY
MPWPDmdP1U
MPWPDmdI1U
REG_PR_SLS_AMT
MPWPDmdP1R
MPWPDmdI1R
RET_QTY
MPWPRtnPU
MPWPRtnIU
RET_AMT
MPWPRtnPR
MPWPRtnIR
Merch Target Plan Forecasts Mapping
The following table shows the mapping for pre-season and in-season Merch Target Plan Forecasts.
Table Column Mapping for Pre-Season (MTP) Mapping for In-Season (MTI)
CAL_HIER_LEVEL
Fiscal Week
Fiscal Week
LOC_HIER_LEVEL
CHANNEL_COUNTRY
CHANNEL_COUNTRY
PROD_HIER_LEVEL
DEPT
DEPT
FCST_DATE_FROM
WEEK
WEEK
LOC_EXT_KEY
CHNL
CHNL
PROD_EXT_KEY
DEPT
DEPT
CUSTSEG_EXT_KEY
NULL
NULL
FCST_TYPE
NPI
PI
CLR_SLS_QTY
MTWPDmdP2U
MTWPDmdI2U
CLR_SLS_AMT
MTWPDmdP2R
MTWPDmdI2R
REG_PR_SLS_QTY
MTWPDmdP1U
MTWPDmdI1U
REG_PR_SLS_AMT
MTWPDmdP1R
MTWPDmdI1R
RET_QTY
MTWPRtnPU
MTWPRtnIU
RET_AMT
MTWPRtnPR
MTWPRtnIR
Location Plan Forecasts Mapping
The following table shows the mapping for pre-season and in-season Location Plan Forecasts.
Table Column Mapping for Pre-Season (LPP) Mapping for In-Season (LPI)
CAL_HIER_LEVEL
Fiscal Week
Fiscal Week
LOC_HIER_LEVEL
LOCATION
LOCATION
PROD_HIER_LEVEL
DEPT
DEPT
FCST_DATE_FROM
WEEK
WEEK
LOC_EXT_KEY
STOR
STOR
PROD_EXT_KEY
DEPT
DEPT
CUSTSEG_EXT_KEY
NULL
NULL
FCST_TYPE
NPI
PI
SLS_QTY
LPWPDmdP1U
LPWPDmdI1U
SLS_AMT
LPWPDmdP1R
LPWPDmdI1R
RET_QTY
LPWPRtnPU
LPWPRtnIU
RET_AMT
LPWPRtnPR
LPWPRtnIR
Location Target Plan Forecasts Mapping
The following table shows the mapping for pre-season and in-season Location Target Plan Forecasts.
Table Column Mapping for Pre-Season (LTP) Mapping for In-Season (LTI)
CAL_HIER_LEVEL
Fiscal Week
Fiscal Week
LOC_HIER_LEVEL
LOCATION
LOCATION
PROD_HIER_LEVEL
CMP
CMP
FCST_DATE_FROM
WEEK
WEEK
LOC_EXT_KEY
STOR
STOR
PROD_EXT_KEY
CMPP
CMPP
CUSTSEG_EXT_KEY
NULL
NULL
FCST_TYPE
NPI
PI
SLS_QTY
LTWPDmdP1U
LTWPDmdI1U
SLS_AMT
LTWPDmdP1R
LTWPDmdI1R
RET_QTY
LTWPRtnPU
LTWPRtnIU
RET_AMT
LTWPRtnPR
LTWPRtnIR
Implementation Steps with RAP Integration
If RAP integration is enabled in the environment (that is, if the customer is going to get data from RMFCS using RDX integration), follow these steps for implementation. The steps assume that RPAS, RASL, UI, and RDX are already deployed:
  1. Run the Batch Process in RAP in Retail Insights (RI) to load the required initial data into the RDX staging tables.
  2. Upload any application-specific hierarchy files and data files that are not coming from RDX into Object Storage.
  3. Once the MFP Cloud Service environment is provisioned, use the bootstrap Build Application task to build the application and use the batch task as set_rdx to just set the Enable RDX Boolean before the initial batch, or run post_hier to enable the RDX Boolean and load/import only the hierarchy files, or run postbuild_rdx to enable the RDX and to load/import initial hierarchy and data files and also run the initial batch. Batch step post_hier can also be run from OAT, to enable the RDX and load the available hierarchy files after building the domain. Use postbuild only if planning to load and use only the GA data set.
  4. Schedule the regular weekly flow in the RI, AIF, and Planning applications in JOS/POM to interface the initial data into the application to get data from both RDX and Object Storage.
    At least post_hier or postbuild_rdx should be run once with at least the calendar hierarchy file before trying to run weekly batch using JOS/POM.
