Daily Batch (batch_daily)
This task is used to schedule a daily plan data export and load on-order files. A retailer may need on-order on a daily basis during an open-to-buy for example.
If a daily load or export is not needed, this step can be skipped as they are scheduled in the weekly load/export process. Steps in this process are also part of the Weekly Batch, so they do not have to schedule this during weekly batch.
Also, if the retailer does not need exports on a daily basis, they can skip scheduling this process.
This task runs the following set of activities in this order:
  • Run Batch Calc: Set Batch Specific Flags
  • If Enable Daily Exports is set to true: Set Export Flags and Export All Plan Versions
  • Measure Load: Load On Order and Process On Order
  • Rebuild Dashboard
