Import Forecasts (imp_fcst)
This task is used to schedule and run all the importer interfaces which import forecast data from AI Foundation using RAP Integration using RDX. If the RDX Enabled flag is set, it runs as part of the weekly batch and as part of JOS/POM schedule. This task can be used to directly execute the interfaces which pull the fact/measures data from AI Foundation using RDX into MFP.
Following is the list of interfaces which are imported from RDX:
  • Forecast from AI Foundation (RSE_FCST_DEMAND_EXP)
For more details about the interfaces and their mapping details, see the Oracle Retail Merchandise Financial Planning Cloud Service Implementation Guide.
