Post Patch Batch (postpatch)
This task is available as an option that executes any necessary batch process after the scheduled patches and which can be used to load hierarchy or data files as part of the patch changes. It also rebuilds all segments to include the patch changes. It runs as part of the patch upgrade, but the customer has the option to disable this task to run as part of post batch. The customer can also run it manually if they need to rerun that step from OAT.
