Set Dimension Attributes (batch_datr)
MFPCS supports the use of location attributes. In order to use the location attributes filter capabilities from the UI, the location attributes need to be registered as dimension attributes. This process registers the loaded location attributes as dimension attributes. Whenever a new set of location attributes is loaded, this task needs to be scheduled. This task runs as part of the Weekly Batch and needs to be scheduled only if a new set of location attributes is loaded in the middle of the week.
