A Appendix: Exports
The tables in this appendix list the measures for the MFP Cloud Service exports.
MFP Cloud Service provides standard exports of multiple versions of approved and working plan data for all major workbook templates Merch Target, Merch Plan, Location Target, and Location Plan. Exported approved plans (Current Plan and Original Plan) data can be used by a retailer to interface with any other applications for reporting purposes or as input to other systems that need MFP Plan data. All exported files are in CSV format. All standard exports are copied to the Object Storage location from where the customer can download them.
For more information related to extracted measures, the approval process, and the administration process related to export, see the Oracle Retail Merchandise Financial Planning Retail Cloud Service User Guide and Oracle Retail Merchandise Financial Planning Cost Cloud Service User Guide
