Level Hierarchy File
The Level hierarchy is an internal application-specific hierarchy to define different levels of the Dynamic Hierarchy Rollup for Product and Location using its attributes in various workbook templates. It is hard coded to have three levels in the MFPCS solution. By default, this file will be included as part of the GA deploy.
File name: lvlh.hdr.csv.dat
File format: comma-separated values file
The following table describes the field in this file.
Name Description
Level
Attribute Roll-Up Level.
Example:
lvld,lvld_label
lvl1,Level 1
lvl2,Level 2
lvl3,Level 3
