Managing Users in OCI IAM
After users are created in OCI IAM, the Administrator can manage user information, manage user groups assigned to users, delete or revoke user access, and reset a password.
The following steps explain how to manage users in OCI IAM:
Log in to the OCI IAM application. The Domains view is shown by default.
Click the Domain name for which you want to create a user. The Domain Overview page appears.
From the Domains Overview page, click Users.
Figure 3-4 Domains Overview Menu
Click the user that you want to edit.
You can update the additional information for the selected user. Once updated, click Update User to confirm the changes.
You can manage the user groups assigned to users in the Groups table.
Assign a New Group
In the Groups table, click Assign user to groups.
From the Assign user to group dialog, select the group or groups to add the user.
Click Assign user.
Remove a Group
In the Groups table, select the group from which you want to remove the user.
Click Remove user from group.
The same user also needs to be deleted from the Merchandise Financial Planning Cloud Service application. This will keep OCI IAM and the application synchronized. Complete the user deletion by following the steps for deleting a user in the User Maintenance chapter of the Oracle Retail Predictive Application Server Cloud Edition Administration Guide.
A user can be deactivated by selecting Deactivate from the More Actions menu and then confirming the selection in the confirmation dialog.
A user can be asked to reset their password by selecting Reset Password and then confirming the selection in the confirmation dialog. The associated user will get an email with a link to reset the password.
