Custom Messages Hierarchy File
MFP Cloud Service also has an additional internal hierarchy for custom messages used in the application called Custom Messages Hierarchy (CMSH). Custom messages used in the application are pre-configured in that hierarchy file and, unless a retailer needs different custom messages, that file does not need to be changed. By default, this file will be included as part of the GA deploy.
File name: cmsh.hdr.csv.dat
File format: comma-separated values file
The following table describes the fields in this file.
| Name | Label | Hierarchy Type | Parent |
CMSD |
Messages |
Main |
None |
Example:
"CMS01","Seeding completed successfully!"
"CMS02","Seeding not successful. Please select Wp Seed Source."
