Location Attributes Hierarchy File
The Location Attributes hierarchy represents attributes associated with locations. These attributes are used to group locations to plan in the Location Planning templates.
This hierarchy is intended to capture all location attributes for all locations. The attributes are then assigned to individual locations. This assignment is used when processing the dynamic rollups in the location planning templates.
| Name | Label | Hierarchy Type | Aggs |
SATV |
Loc Attribute Value |
Main |
None |
SATT |
Loc Attribute |
Main |
SATV |
File name: satr.hdr.csv.dat
File format: comma-separated values file
The following table describes the fields in this file.
| Name | Description |
The various values that an attribute might have. For example, the climate attribute might take the values cold, hot, or humid. |
Loc Attribute |
The name of a location attribute, such as climate, store volume, and so on. |
Notes:
This hierarchy data can be imported as part of RAP integration from RMFCS or the customer can also directly provide the location attribute hierarchy with at least one valid data.
Example:
satv,satv_label,satt,satt_label grade,Sales Perf Grp,grade,Sales Perf Grp space,Space,space,Space sfmt1,Downtown,sfmt,Store Format sfmt2,Strip Mall,sfmt,Store Format sfmt3,Standalone,sfmt,Store Format clmt1,Marine,clmt,Climate clmt2,Cold,clmt,Climate clmt3,Very Cold,clmt,Climate clmt4,Hot Dry,clmt,Climate clmt5,Mixed Dry,clmt,Climate clmt6,Mixed Humid,clmt,Climate clmt7,Hot Humid,clmt,Climate clmt8,Mediterranean,clmt,Climate clmt9,N/A,clmt,Climate
